Results 1 to 13 of 17
Thread: furnace blower cycles on and off
11-28-2008, 08:27 PM #1
- Dec 2007
- 12
Hello, I am working on a mobile home furnace, it is a Homemiller furnace down flow. The problem i am having is, the blower motor keeps on cycling on and off. when the burners lit the furnace heats up and i can watch the fan limit heat up and turn the blower on then the burners shut off and the fan continues to run until the fan limit cools down and the blower shuts off, then i can watch the fan limit heat up again without the furnace liting and it will kick the fan back on until it cools back down. it will continue to do this every minute all day long. i have read some post with similar problems but never really nailed the problem. the whole furnace was cleaned, the air flow is good and i adjusted the fan on and fan off settings, i set the cut in at 140 and the cut out at 90. any help would be greatly appreciated.
thanks
11-28-2008, 08:43 PM #2
Twilli says the answer is in this song....
No Heat No Cool You need Action Fast
11-28-2008, 11:25 PM #3
- Jun 2008
- 62
Are you a HVAC tech? This is a pretty basic problem. Your furnace is shutting down on high limit and fan is coming back on because it is not cooling down enough. Since your not sure what to do you need someone to look at it who knows how to diagnose it as it could be a safety issue.
11-29-2008, 01:36 AM #4
- Sep 2008
- 7
Got to love those spiders, but unless they are lighting matches I dont see how the limit will continue to heat up all day long without the burner coming on.
11-29-2008, 04:41 AM #5
Seen too many homes burnt up from those old "Home" furnaces, they look great in the dumpster out back.
You can't fix stupid
11-29-2008, 05:08 AM #6
Get post count up, and apply for pro membership.
And post questions like these in the pro tech forum, where they can be answered.
There is more then one limit on most MH furnaces.
11-29-2008, 06:32 AM #7
- May 2006
- 317
11-29-2008, 06:37 AM #8
There is a reason that the unit is going out on high limit ,and you need to call a professional serviceman to check your unit before you have fire.
"Everyday above ground, is a good day".
"But everyday that you have made a difference in someones life, may insure you stay above ground a little longer".<aircooled>
11-29-2008, 07:22 AM #9
11-29-2008, 08:39 AM #10
- Dec 2007
- 12
i dont think i am making myself clear. the furnace isnt cycling on high limit. the furnace runs thru a cycle and once the fan limit cools down to 90 degrees the fan shuts off, now at this point i watch the fan limit creep back up to 130 degrees and the fan will turn back on and it will cool back down to 90 degrees but there is no call for heat at all. so what is happing is the heat exchanger isnt cooling down and staying cooled down.
11-29-2008, 08:42 AM #11
Ok, then WHY is the furnace getting to hot or is the fan limit control BAD.
Did you check temperature rise and check gas manifold pressure,indoor coil clean ,filters clean blower running at design speed.All these things need to be check before you move temperature settings on fan/limit control.Might be that the limit control is old and not sensing properly. But most cycle off at 100*. With it set to cycle fan of at 90* its building back up temps for some reason."Everyday above ground, is a good day".
11-29-2008, 08:43 AM #12
11-29-2008, 08:51 AM #13
Twilli obviuosly ate to many mushrooms and made an inaccurate diagnosis. Twilli still likes the song though.
