    Nov 2008
    Comment on quoted AC system pricing
    khoile,
    You need to read the site rules before you post.
    Please read site rules, Thank you.
    No pricing questions.
    You may want to do your own load calc to see what size equipment you need.
    http://hvaccomputer.com/talkref.asp
    Nov 2008
    Oops Sorry. Will not happen again.
    Massachusetts
    Here's what you need to know.
    Did the company do a Manual 'J' load calc? If yes, continue with them. If no, drop them and find one that will do the calc. Why? Because the Load Calculation is like the frame of a car, the foundation of a home. Without the load calc, all the rest is just guessed at and stuck together. Without a good frame, when you run the system it'll just fall apart. Not literally but figuratively. It's likely to be out of balance, meaning different temps in each room, short cycle or not have enough capacity for a hot day. Either way, you're risking your entire investment by selecting a company that doesn't do a Manual 'J' calculation before quoting the job. After the Man J come Manual 'D', which is a duct system designed on the loads from Man 'J'. The Man 'S' is used to properly size the equipment, again based on Man 'J'. So you see, everything begins with Manual 'J' calculations. Without them, no 'D', no 'S', you pay big money for something that there's no confidence that it will work at all. Will it cost more getting it from a company that does it right? Sure. Don't you think a car with a frame costs more than one without? You only get what you pay for. If you cut corners to save money, expect the company you're dealing with to cut corners to make money. So you both cheat, they make some money, you end up back here asking what's wrong with your new AC system. We reply, "Well first, did you have a Manual "J" load calculation done?" You say "No" and we say "Can't help you".
    Nov 2008
    Massachusetts
    Quote Originally Posted by skippedover View Post
    Amen. My brother-in-law works for Carrier Corporate, and he takes calls all day from homeowners who want Carrier CORPORATION to size and price the equipment. I suppose the worst part of his job is that he can't laugh at them on the phone when they get upset that he can't price out and size units for them...I can't wait to see him on Thanksgiving, he always has some funny stories to share about the calls he receives...last week he told me he got a call from a homeowner in Michigan who had his phone in one hand, and his cracked heat exchanger in the other...
