Results 1 to 1 of 1
11-24-2008, 02:47 PM #1
- Jan 2006
- 79
iLon 100 e3 - COV Log not working ?
Ok, I read the help section on the iLon e3 and cannot figure out why this is not working.
I have a controller hooked up to an iLon 100. The NV type is a SNVT_count_inc and the values are always either 0 or 100 (off and on respectively). I created the NVE and its pulling the data with no problems (even showing the proper value that I setup in the presets).
When I setup the Points in the Log, I have the following:
The intent was to log every change of value. However, its logging every 5 minutes anyway. What did I setup wrong? Let me know if I missed any pertinent information.Code:"Log only at poll rate" is unchecked Each point: Poll Rate: 300s Min delta time: 60s Min delta change: 1
Thanks in advance!
