Results 1 to 12 of 12
Thread: Garage heater?
    Aug 2008
    Delaware Ohio
    Garage heater?
    I know this probably isn't the best forum for something like this....
    But I thought maybe some of you may have an idea of what I am looking for.
    I am looking for a heater for my garage/workshop.
    I usually tinker with my dirtbikes and do some handyman wood working in the winter time.
    Its about 300 square feet.
    Any recommendations on something for this kind of application?
    I do have 200 AMP service so I could run a dedicated circuit breaker just for the heater itself.....
    I am sure a 110 heater would be fine... even portable ones
    May 2008
    Augusta, Ks
    HOT DAWG, but you'll need gas line run out to yer garage.
    Aug 2008
    Delaware Ohio
    i don't have gas at my house.... i was looking for something more of like an electric one.
    I kinda wouldn't mind having it hang from the ceiling so its out of the way... but would like to be able to have it swivel so i can direct the heat when needed
    Milwaukee Wisconsin
    Aug 2008
    Delaware Ohio
    that grainger site has a ton to choose from....
    I kinda like the idea of this one.... I could mount it right above my work bench
    http://www.grainger.com/Grainger/items/1UCP9
    Jul 2003
    sacratomato
    Cheap, Fast, Good. Pick two
    Those electric one's look good.
    FWIW. You can have gas via a propane tank too.
    Aug 2008
    Delaware Ohio
    i've heard that those Infrared Heater's put out some descent heat.
    I've never experienced one in person or anything....
    But with this thing... it looks like all i would have to do is run a dedecated 208 20amp circuit and its done....
    10K BTU's sounds pretty decsent....
    I don't need it to be 70 degrees or anything in my work shop.. just warm enough that my fingers don't fall off
    Also.. i didn't really think about using a propane tank..
    I wonder how long one tank would last...
    Milwaukee Wisconsin
    UMMMMM!
    You have 208v.?
    Aug 2008
    Delaware Ohio
    i just found this propane one at tractor supply...
    its more portable... and may be more of what I am looking for
    http://www.tractorsupply.com/webapp/wcs/stores/servlet/ProductDisplay_10551_10001_123818_-1______14239|14273|14278|123818?listingPage=true&S pecial=false
    Colorado flatland native
    Quote Originally Posted by panaman View Post
    They heat nice, bright tho..... same principal as the ones McD's used to use.
    Walter Matthau
    pittsburgh,pa
    electric may not be what you are looking for, 10k=50a single phase costly to install as well as operate best to do some research there are some options to look at.
    Aug 2008
    Delaware Ohio
    Actually I think found what will work good for me.
    Its a Protemp 18,000 BTU Propane Cabinet Utility Heater
    here is the details
    Safe - built-in oxygen sensor turns heater off if unsafe oxygen levels occur, auto shut-off tip over device. Effective - clean quiet instant heat, no electricity required. Portable - front & rear rolling casters make it easy to move. Easy to use - variable heat setting control valve and integrated knob ignition. Heavy Duty Construction - wind resistant burner system.
    * Warm-glow heating plaques
    * Built in ODS (Oxygen Depletion Sensor)
    * Standard 20 lb. propane cylinder connection
    * Diamond tread design with built-in handles
    * Hose and regulator included
    its at tractor supply company and it costs $139.99.
    I think that being mobile will allow me to use it in other applications.. like bringing to a buddies house if we are working on something in his garage.....
    I do believe that the 20lb propane tank just sits in side of it.....
    here's a picture..
