Thread: Trane trouble
    Trane trouble
    The problem I am having with system it is a trane heat pump with gas backup when I switch it to run on Emergency heat when the Thermostat says in upper left corner the Emergency heat is on and auxilary heat is on Furnace blows warm air but when it temp rises a degree or two it switches over and says just Emergency heat it only blows cool air, any ideas what this could be.
    central america
    thermostat control issue, call expert heat pump guy...
    Call the installer back.
    Nov 2008
    MI
    Sounds like someone didn't wire the stat correctly.
