    emergency heat switch
    On my heat pump thermostat, I have a switch setting for "Emergency Heat". I understand that this is for the times below 30 degrees when it's blowing only cold air?. Question is how long can I leave it in that position? Overnight is what I'm thinking and turning it back to normal heat during the day.
    Lancaster PA
    Emergency heat. Is for when the heat pump doesn't work. Or if you are having a freezing rain.
    If you use it the way you want. You will have a high heating bill.
    Jun 2007
    Round Rock
    I would leave it on the heat setting and don't set it on emergency heat. Most thermostats will turn on the emergency heat when the heat pump can no longer keep up. Another option is to have your hvac contractor install an outdoor thermostat and lock the heat pump out below 30 degrees or wherever your balance point is. This will prevent the heat pump AND heat strips running simultaneously and really running up your electric bill.
    Lancaster PA
    Quote Originally Posted by bmathews View Post
    Economical balance point will be well below 30°.
