Results 1 to 11 of 11
    Aug 2008
    OK fellas, what's going on here
    **Lennox 15 y/0 gas-fired furnace (not NG)
    **Ran dirty and sooty for years until (finally) got tech back to clean and install the device that introduces gas into the thing-been running fine this heating season
    **Fairly new MERV 12 filter (been running these for years w/o a prob.
    **Just whalago (while a go here in Dixie) the motor took 2-3x longer than usual to get up to speed. Sounded sorta like an older car w/the battery down or starter beginning to go.
    **I have THOUGHT here recently that it was taking longer, but hadn't really listened for it.
    Thoughts and opinions are appreciated and noted.
    AG
    North Miss.
    Aug 2008
    JUST WANT AN OPINION
    Quote Originally Posted by the dangling wrangler View Post
    I wouldn't dare try to repair anything like this, JUST OPINIONS
    Nov 2008
    not in order of likelihood
    The motor capacitor changed value or failed.
    A high resistance (loose or corroded connection or bad relay contacts) upstream of the motor.
    An abnormally high load on the motor.
    Motor bearing failure.
    Bad mojo or bad juju in which case you hire these guys
    http://www.youtube.com/watch?v=Ewu1laA2nmI
    Good relay contacts have 30mV or less at rated current, bad ones have more than 100mV.
    Aug 2008
    Gratis
    Quote Originally Posted by WhoIsThat? View Post
    That's all I needed
    Apr 2008
    Alberta Canada
    My Opinion is
    Quote Originally Posted by AvantGarde View Post
    It is almost impossible to troubleshoot from here, you should call a professional.
    Do it right the first time.
    Northeast Ohio
    What ever the cause, the symptoms are not good and the prognosis is it will need professional help soon.
    DEM
    Jul 2002
    Zelienople, Pa
    15 years old. Start thinking about a replacement upgrade.
    Jan 2002
    Ft.Worth,Tx
    If he's in the south must be the MoJo , the juju is north of the Mason Dixon Line.
    'Life begins with the journey each day'
    Nov 2008
    Quote Originally Posted by aircooled53 View Post
    I would ask how you know that, but I have to work some chicken bones against a troublesome neighbor.
    Or maybe I'll just make a little doll and stick pins in it.
    Aug 2008
    Snarl
    Quote Originally Posted by Gunnery Sergeant Hartman View Post
    Snarl again
