    Nov 2008
    duelfuel ? tsat th8320
    I have a 3ton heatpump and a twostage gas furance with variable speed and I am trying to config the tsat . I do have the outdoor temp probe and I have programmed the tsat to turn off the heatpump at 30. But I can't figerout the system type in the config menu. Can someone help me with the config for this system . Thanks, Kurt
    r=24
    b=c
    y=cool
    w=heat or w1
    0=reversing valve
    g= fan
    black=w2$
    I'm not real sure what you are asking?
    You ask for configuration..........you do have the manual.......duh
    what is purpose of listing the wire color/designation
    maybe ask whoever sold you that T-stat
    Dec 2006
    Middle Tennessee
    Quote Originally Posted by kurtflys View Post
    I can't figure out the system type in the config menu.
    most homeowners can't figure out how to wire and configure a regular stat
    your dual fuel stat is more complicated
    only qualified techs should be installing dual fuel stats!
    2 heat/1 cool.
    If you have a 2 stage furnace, you should get the IAQ model to properly control the staging instead of using the timer in the furnace. Ask your dealer.
    Nov 2008
    I do appreciate all you're guys help! I got it config anyway....
