Thread: HRV
    Cedar Grove, Wi-Sheboygan
    HRV
    Can HRV's be installed in a attic space ? I ask this because my installer who I had over the other day when we determined the only way to be able to have a deicated ducting for the HRV is to install the HEV in my attic, otherwise I would have to have the unit installed trhu my HVAC equipment which I would preferr a dedicated ducting.
    Yes, you can install it that way.
    I prefer to use the heat/cooling system duct work though.
    Apr 2008
    Alberta Canada
    You better becareful
    HRVs produce moisture and if you are in colder climate the drain could freeze. Whats wrong with running it through existing ducts if you have ample return airs.
    Do it right the first time.
    Madison, WI/Cape Coral, FL
    HRVs should be located inside the conditioned space in cold climates. WI attics are cold and cause condensation inside the ducts containing damp house air. Basement is much better than the attic unless atttic is warm during cold weather.
    Exhaust stale air from the center of high spots inside the home like largest bath. Fresh air is cool after flowing through the HRV and should be mixed with house air befor distributing the fresh air throught the home. A little cool air supplied high in the conditioned space throughout the home is not noticiable. Regards TB
