what in the hell??
what i also hate to see is duct seal spread all over the F&%$##@!* place.
how do these places get buy.
even if i were a builder i would want quality in the homes i built.. i dont get it..
Gotta have the right tool for the job!
Where is all the stuff MADE IN THE USA?
"Thats what we do Troy. Incredible, Invisible, Imbelivable things. We are an Unseen, Unknown, Unvincible fraternity of craftsman.."
Quality in a new home? That costs money, especially in the cheapos they won't spend it.
I've heard conflicting answers, is union in the furnace cabinet OK?
Not where I work. Code states that it has to be outside the cabinet.
Not as lean, not as mean, but I'm still a hardcore, ass-kicking, hard charging Marine! Oohrah!
What is that thing on the second hole for AC drain pan? Looks like a clean out?
I r the king of the world!...or at least I get to stand on the roof and look down on the rest of yall
drain pan overflow switch
around here 80% yes, 90% no.
without louvered door they consider it a closed space just like inside a wall.
See that's weird. I always thought the union should be outside but for the past couple years we've been putting them inside. The inspectors here haven't said a word. and just like the pic, it's tight and difficult to install and remove them. But we started doing it to keep homeowners from pissing around with it and teeing into their gas lines.
lucky to find a union here
in the furnace is OK, if its even there lol
commonly find low voltage wire wrapped in black duct tape even outside
duct sealing
 Originally Posted by Pascone10
what in the hell??
I'm confused over this post. Do you have a problem with complying with the code where it requires returns be sealed within 10 ft. of the AHU or are you complaining that they used UL 181 foil tape instead of mastic as they should.
How do you seal your ducts so:
-it meets code
-remains an effective seal after yrs of use.?
Keep the fire inside the fireplace.
-it meets code
not at all do i have a problem with code. what i have a problem is with the lack of pride in work. these new construction jobs are put together like crap if you ask me. im not saying all of them but all the ones i work on around here are! i mean the duct seal for example. they duct seal the joint and about a foot onto the plenums and furnace. it just looks like crap. so great it passes but at teh end of the day we talk about installation being key and the guy installing the unit is the same guy that says after every job "you cant see it from my house". it just bothers me.
That it is, but it's installed UPSIDE DOWN! Aquaguard 3100. Dumb question, but was it connected? I've never tried running one upside down; I'm not sure if it'd affect the operation of the float switch. Some of the other float switches are definitely orientation-sensitive.
workmanship a lost art?
Pascone, I agree and appreciate the sinking feeling no one gives a hoot about workmanship anymore. No pride.
I think one of the problems with sloppy duct mastic jobs is they HVAC contractor originally did not want to seal the ducts because he normally does not. Now, he has to find the cheapest guy on his crew to do this "menial" work. The kid stuck doing it does not forsee a career in HVAC is only there to make enough beer money for the weekend. Fine, he'll slop it on so it passes. As long as it's good enough to keep his boss off his butt like a diaper, he's satisfied.
Sad commentary on our current state, wouldn't you say?
i will say that companies who regulary seal ducts have figured out how to do it neatly and quicxly yet still meet the specifications such as 6% max. leakage. Short learning curve, when someone gives a hoot and supervises the job.
- You may not post replies
- You may not edit your posts
Forum Rules
