    Nov 2008
    Kansas City
    LON API Migration to BACnet
    I have an existing LON API Circon system that I would like to get migrated over to a BACnet MS/TP (Metasys) : system and use the same twisted pair.
    I'll be replacing the existing LON controllers with BACnet. Can they reside on the same wire? What are the side effects?
    May 2002
    Do you need to do much with it? Maybe you can slap on a Loytec LGATE and transfer those points over. I think you should also be able to get the CP values.
    Nov 2005
    Shreveport, Louisiana
    You can not use the same wire for LON devices and BacNet devices. one or the other.
    UA Local 141
