Results 1 to 13 of 16
    Southern Nevada
    Best hook up for Thermostat, Heat pump/propane furnace
    I repair A/c and heating as well as many other Items, Mostly commercial refrigeration. I completed my refrigeration and heating school in the early 90s. Kept all my grades in the upper 90%. Since I live in a small desert community I have to do a large variety of things to stay busy. The point is that I don't get daily or even monthly experiance on HeatPumps, A/C etc.
    Now I am installing a White rogers 1F83-277 Thermostat for a customer. I am installing it to operate a GMV95/GCV9 two-stage PROPANE furnace and a GSH140421ad HeatPump from Goodman.
    I can hook it up to use the heatpump as an A/C very easily. But I am trying to hook the heat pump up so that it runs on the thermostat as the primary heat and the Furnace comes in as a back up. I need to get a fossil fuel kit to do this. But for the two weeks or more I am waiting for the parts The customer would like heat. I could just hook up the funace and wait but It seems to me there is a way to wire this so that the Heat pump works on the thermostat as it normaly would and if I select emergency heat the furnace will take over.
    Does anybody have any ideas for me or a better answer than I am trying to do? I mainly just want to learn how to do this even though it is not important for this application.
    Apr 2005
    N. E. Missouri
    Since your previous post concerning this same issue was closed as DIY, I really wouldn't expect anyone to give you step by step instructions or any further information.
    There are reasons for the no DIY rule at this site...
    Do not argue with an idiot. He will drag you down to his level and beat you with experience.
    Southern Nevada
    I guess I could add some info in case somebody not familial with these items could input. The The thermostat can be set for Multi stage or heatpump, and of couse single stage. Has a L, C, R, W2, E/W1, Y2, Y1, G, O, B connections as well as a few others for de-humidifier etc... The furnace is a two stage gas fired warm air furnace with a toggle on the board for single stage operation were it operates in low stage for a time and then switches to high stage. Thermotat connections O, YLO, Y, B/C, G, R, W1, W2, Dehum-Twin, ... The Heat pump.. C, W2, O, Y, R....
    Apr 2005
    N. E. Missouri
    Your best option, if you are indeed a professional, is to get your post count up and apply for professional membership. Then you can post your questions in the professional forum where the pro's discuss those ornery HVAC problems.
    Maybe read the rules regarding DIY and why it is not allowed here. It's not a case of no-one understanding your question.
    Southern Nevada
    Quote Originally Posted by mrs reb77 View Post
    Except I am not a do it your selfer. I am making my living with this and just don't happen to get the experiance as people in larger areas. I also don't have anybody to call in to give me advise because I am in the middle of nowhere. I know how to hook up a thermostat. I haven't been able to keep up with the times because I do so many other things. I am just having a problem getting my mind around this one.. Looking for the wisdom of experiance. If you close this one or nobody answers then life will go on for me,,, thanks anyway...
    Apr 2005
    N. E. Missouri
    This is an open area of the forum and step by step questions are not answered here. I thought that was made clear?
    If you are a pro, there are many resources available to you regardless of location in the United States (or even abroad!). Call technical support, look at the manufacturer's website, call your supplier etc. If you aren't a pro, you probably don't know about these options...we're a one-man shop in a rural area and we get support from many different sources...
    Jun 2007
    The Twilight Zone
    Call White-Rogers, the thermostat manufacturer. They should have a technical help line.
    Jun 2007
    The Twilight Zone
    ...we're a one-man shop in a rural area...
    But your name is Mrs Reb77?
    Southern Nevada
    Sorry, staying pretty busy and didn't get the full run down on how your site works exactly I guess. I am not sure what my post count is exactly either. Read the rules and didn't seem to read that this area wasn't for such questions. I am guessing now that this is for home owners that have simple noise, shortcycle, blown fuse type problems or non-repair problems and want to run it by people who are indeed professionals and get their opinions. And you have another section that if I was also one of those professionals I could ask this question.. Then I would need to do a little most reading on this site and figure out how to get to the professional area, if I am indeed a professional. I think I have it now.. Sorry again for mis-posting...
    Western NC
    Quote Originally Posted by jimq40 View Post
    I know exactly what your trying to do and your trying to do it wrong!!!
    2 weeks to get parts??? Are you frickin kidding me? If you work in refrigeration as you claim, then you know that a part ordered at 5PM can be on your doorstep by 10AM the next morning. 2 weeks.....I can snail mail parts and have them here in under a week. No wonder you don't get that much business, your customers can order parts on ebay and have them installed faster than you can even get them...
    Point in fact, you need the duel fuel kit. And 2 weeks to get it is a little crazy if you ask me. Something isn't right here. I call bullsh!t.
    However, if you are a pro, then you should know the resources at hand to hack together something in the time being. But I'm curious...is this a new install? Why isn't there a fuel kit already?
    Southern Nevada
    Quote Originally Posted by gary_g View Post
    Thanks.. I was just looking for a quick answer, the easy way out.. I guess your right, sometimes the simple answers are the last ones we think of.. Too easy...
    Apr 2005
    N. E. Missouri
    1 man shop, 1 woman office!
    Jun 2007
    The Twilight Zone
    You are the BOSS!!
    Take care.
