Results 27 to 39 of 46
11-20-2008, 10:55 PM #27
- Sep 2008
- Cedar Rapids, IA
- 473
Based on your costs for electricity and propane, you should use electric resistance heating for backup and forget the propane.
Your cost for 1000000 btus on propane will be $45.63
For the same energy w resistance heating $32.24
For the same energy w an air to air heatpump with a COP of 2 $16.12
If you go all electric a lot of the electric companies will give you lower electric rates for the winter season which may help even more. Also check for rebates BEFORE you buy anything as they may have specific requirements you will have to meet.
I'm changing my own house over from propane to electric, so all I had to do was plug in the numbers in the spreadsheet I already created. I have a 3200 sq ft home and will save about $2000 per year. This is enough to justify the air to air heatpump, but not a geothermal, mostly because I can get a $.04/KW rate for the winter heating season from my utility.
11-20-2008, 10:59 PM #28
- Jan 2007
- Westchester Co, NY
- 104
11-21-2008, 01:10 AM #29
I'm confused about the boiler. How is this house heated and cooled?
In ny? Use get energy smart. 10% incentive plus tax cred in 09 plus audit for low hanging losses.
Carrier/Bryant infinity is truely mind boggling but $.
Might be good Acadia hp application, also $
11-21-2008, 09:43 AM #30
Professional Member*
- Jul 2008
- Poestenkill, NY
- 764
lol - it's a little after the fact now - but I was going to suggest using the average of your fuel consumption estimate (2000 gal /yr + 1500 gal /yr / 2) minus estimated hot water heating fuel (200 gal /yr), yielding
(1550 gal / yr) (139,000 btu / gal) (65% everall efficiency) = 140,042,500 btu /yr.
Lucky guess.
11-21-2008, 09:50 AM #31
- Jan 2007
- 104
11-21-2008, 09:59 AM #32
- Jul 2008
- Poestenkill, NY
- 764
Doesn't sound too far out of whack, I guess.
Here's another short-cut metric:
You said your design heat loss was 64,000 btu / hr I think?
64 mbh / 2500 sq ft = 25.6 btuh / sq ft.
Residential structures "usually" have a design heat loss somewhere between 20 and 50 btu's per sq ft. That's a big range - but as you're gathering, there's a lot of variables!
In any event - 25.6 btu / sq ft is pretty good in our area.
11-21-2008, 10:10 AM #33
- Jul 2008
- Poestenkill, NY
- 764
Double post, sorry.
11-21-2008, 10:59 AM #34
Very well insulated house.
R29 walls, R38 attic.
Is that what yours is.
Also, how tight your house is has a large impact on heat loss.
11-21-2008, 11:59 AM #35
- Jan 2007
- 104
11-21-2008, 12:26 PM #36
- Jan 2007
- 104
11-21-2008, 03:52 PM #37
- Oct 2008
- 483
I'd say that is correct.
The R value is a linear part of the equation, not exponential or otherwise.
11-21-2008, 05:21 PM #38
Member
- Oct 2006
- Emerald Coast, FL 30.1N 85.8W
- 681
doubtful your heat load is 1.5 times cooling load in NY
Those are numbers we would see in a southern city like Atlanta.
You're paying 11 cents/KWH -- that seems low for the Northeast -- what about distribution, franchise fees, etc.
I know for a fact that the former PECO electric in the Philly area was close to 3 times the national average.
11-21-2008, 08:51 PM #39
- Jan 2007
- 104
emcoasthvacr - Unfortunatly - I cannot challenge the Heat loads at this time, however each one of my 3 potiential installers have said after they get the job, they will share the entire heat load calculations. They did not want to give it out i guess to protect their work - which is fair. I am sure i will have questions here once i see it to ensure its accurate!!
On the Electricity - yes - i am paying .11/KWH and locked in for the year. this includes all delivery, taxes etc etc
thanks for your input
) I have compiled the below. I am unable to get everything but i hope its sufficient
