    Where is air is clean
    Circulator pump whistle
    A new B&G NRF-22 all is good no problems,,but after running about 10 mins it begins to whistle,,not sure if this it due to the water temp or the loop it's on ,,maybe moving the water too fast?? The other 2 zones have the same pumps with no noise at all. All pumps are mounted properly as per B&G instructions,,
    Artie
    Massachusetts
    Change it while it's still in warranty.
    I'd take the motor cartridge off and clean up the impeller and housing. Could be a slug of solder or some other type of debris trapped inside.
    If that don't work, change it out with a Taco 007.
    Aug 2008
    Did you add the oil that came with the new pump?
    Quote Originally Posted by mike robinson View Post
    The NRF-22 circulator is a wet rotor design with no oil ports that I am aware of. Put quite a few of these circs on, but unfortunately replaced quite a few after just a few years. I have one of these on my new addition, still going strong after 4 yrs. I still like Taco better.
    Aug 2008
    Is that one of the little in line pumps that seems to run forever?
