Results 1 to 13 of 14
    Nov 2008
    cincinnati oh
    You don't need caps?!!
    [IMG][/IMG]I work in a facility as a maintenance tech. They put me in charge of HVAC so I have learned a few things from the licensed guys there and an outside companies owner who is a AC guru. (you know you are Chris) Well a couple months ago they got rid of the guru and hired a big, well established company. The put a new compressor in a P.O.S water chilled unit. # weeks after we had them in to run new control wires for are hot water pumps for office heat. The payroll lady was complaining about it being hot so I looked at the ac and first I found no caps on the valves, Second thing I noticed was the sight glass leaking. I got the guy who helped installed it and he said quote" You dont need caps." Then I pointed out the sight glass and he said he would put his gages on it and check the pressures. WTF I'm barely educated on this and I dont mess up like that.
    [IMG][/IMG]
    You been following me around with a camera???
    I have been collecting caps from every piece of equipment that I work on for the last 10 years.
    ky
    I was wondering how you could run the motor without caps
    Then
    Oh never mind
    Yeah those big companies are soooooooooo much better.
    Thanks for the compliment George it means alot to me.
    Lets do that lunch thing .
    Madison, Wisconsin
    If you put caps on them you are destroying the native mud dauber wasp nesting habitat!
    I r the king of the world!...or at least I get to stand on the roof and look down on the rest of yall
    Jun 2007
    Oh my that's the worse brazing job I've ever seen....
    I tell ya what... I have a bad day and forget a cap... GOD HELP ME...
    The Boss will be on my *SS
    Nov 2008
    details
    Wisconsin
    New compressor and didn't change the drier? Date code is from 05, must have figured it was new enough. This is why I never run out of work.
    Looks like some of the great work I see around here as well........
    Nov 2008
    cincinnati oh
    The dryer is from are stock. It was replaced.
    Saint Augustine, Florida, United States
    If you swept up all that dust, you might not even see that leak!!
    The South
    You don't need no stinking caps.
    Is that drier pointed in the right direction?
    GO DAWGS!
