Results 14 to 17 of 17
    Cedar Rapids, IA
    Quote Originally Posted by Chris_Worthingt View Post
    Who said anything about start-up?
    I thought a normal situation where this this would be used i.e. Pump down would occur at the end of a cycle
    There are many app's where timing out a safety is called for, the facts, not a band-aid
    It is not a good idea to bypass a low pressure control w a timer for pump down purposes. A timer to bypass a low pressure control on startup in cold weather is common, but the question here seems to be about prolonging pump down. Scroll compressors can be damaged by pumping down too low. If the timer ever failed this could happen. It would be a better idea to put a 2nd low pressure switch in. (or widen the cut in cut out differential spread on the existing control)
    Mount Airy, MD
    Quote Originally Posted by bob_scheel View Post
    Its done everyday in the refer world among others, never ever caused an issue and is generally a required part of the sequence of operations, timing out a safety in a lot of circumstances is a requirement, period
    Hampton Roads, Virginia
    Johnson make a low pressure switch with built in time delay the P29 series.
    "There is plenty of room at the top because very few people care to travel beyond the average route. And so most of us seem satisfied to remain within the confines of mediocrity." -- Benjamin Nnamdi Azikiwe, first president of Nigeria
    "It's not the customer's job to know what they want." -- Steve Jobs
    East of big city prices.
    Can you name a few refrigeration systems that use scroll compressors for pumpdown? I need to know for reference. I wonder how low pressure they really go.
