Results 1 to 13 of 17
Thread: LP switch time delay
11-05-2008, 07:09 PM #1
- Nov 2008
- 4
Help me- I can't figure out how to draw a time delay into a simple safety circuit. High pressure, Low pressure switches. I need the unit to continue running after the low pressure switch opens for a couple seconds. I just can't figure out how to draw it.
11-05-2008, 07:56 PM #2
*************** TDR
******* |----------O------------------ Neutral
**Line ---|--HP--|--LP--|--- LOAD
I would just draw something like this.Last edited by dapper; 11-05-2008 at 09:44 PM. Reason: Didn't read the criteria right at first
11-05-2008, 08:59 PM #3
Professional Member*
- Jan 2008
- Dallas ,Texas
- 3,510
Why would you want to keep a compressor running after the low pressure switch opens? What does 3 seconds matter?
UA 100
It takes three people to do anything around here. Two do the work, one explains to the crowd of people who showed up when they seen smoke and flames.
11-05-2008, 09:51 PM #4
This type of time delay (delay-on-break) is generally used to bypass the low pressure switch on compressor start-up when there might be a cold evap or condenser. Not sure why it would run after the LP opens otherwise.
11-09-2008, 12:14 AM #5
I would rather find the solution to why the LP is dropping that low on start up in the first place the delay on break relay is mearly a Band-Aid solution check the super heat and LP cut out settings.
11-09-2008, 03:54 AM #6
Maybe this is apprenticeship homework!!
11-09-2008, 08:15 AM #7
Not a Band-Aid solution at all. A very common and necessary solution often provided from the factory for those of us in much colder climates than you guys.
11-09-2008, 09:37 AM #8
11-09-2008, 10:01 AM #9
Real common in pump-downs but I'm also thinking about heat pumps and water source heat pumps without pump-down.
11-09-2008, 10:11 AM #10
11-09-2008, 01:37 PM #11
- Jan 2008
- Dallas ,Texas
- 3,510
The OP doesn`t say whether he is trying to bypass at start-up. So my assumption was why trying to bypass at safety on a normal safety trip out.
I know most manufacturers have an approved low ambient start kit for this purpose and more safisticated controls should have this built in.UA 100
11-09-2008, 01:51 PM #12
Who said anything about start-up?
I thought a normal situation where this this would be used i.e. Pump down would occur at the end of a cycle
There are many app's where timing out a safety is called for, the facts, not a band-aid
11-09-2008, 02:17 PM #13
http://www.icmcontrols.com/products/....php?cat_pk=21
I have used with good luck"Paddle faster, I hear banjo music"
