Results 1 to 2 of 2
    Feb 2007
    Northern Ontario
    Talking Garland air deck
    Ive had multiple troubles with garland air deck ovens with the pilots not proving or failing on light up wanted to know of any solutions. I have tested all gas pressures strong spark. etc I have changed pilot assembly. The new ignition module comes with larger orifice which I figured they had problems so they want to increase pilot size to ensure sensing with all the air movement in oven..thanks for any help..
    You miss 100% of the shots you don't take...
    Feb 2007
    Northern Ontario
    thought id reply to my own post
    I found that wwhen you order a new ignition module from garland they ship a much larger pilot orifice with it .. this allows for a much easier pilot to watch that can handle air turbulance in oven... I made some air adjustments and pilot pressure adjustments all seems ok now..
