Page 1 of 5 12345 LastLast
Results 1 to 13 of 56
    Oct 2008
    Indiana
    Debating gas vs electric backup for heat pump
    I am getting ready to replace a system in my home. Presently I have a heat pump with a gas furnace backup, both about 20 years old. For the new system I am seriously considering going to electric heat backup instead of gas.
    My thinking is that with gas backup, I can't run both heat pump and gas simultaneously, so once the temp drops below the point where the heat pump can heat the house by itself, then I am never using the heat pump. Whereas with electric, I can run heat pump and electric heat together, so I can use the heat pump down to a much lower outside temperature.
    My utility cost is about $1.10 per therm for gas, and $1.45 per therm for electricity.
    Does this make sense?
    Is there such a thing as a system that uses all 3 fuel types? In other words use the heat pump as the primary, electric strip for additional heat down to a certain outside temp, and gas heat for very low outside temp and during heat pump defrost cycles?
    -jim-
    Oct 2008
    *where ya from*
    just curious what type of region u live in, this info will allow me to give u a much more informative reply
    Dallas & Longview, TX
    At the lower temps that the furnace would run, the HP would be less effecient than the gas. The strips are always less efficient than gas.
    Oct 2008
    Indiana
    Location is central Indiana. With my electric rates it seems as though the heat pump is more efficient than gas at least down to 0.
    This will be a 4-ton heat pump. These are some sample numbers I came up with:
    At 0 degrees, the heat pump puts out a net of 18,000 btu/hr for a cost of $0.15/hr. If the total need for heat at that temp is 54,000 btu/hr (rough guess) then I can get 1/3 of my heat from the heat pump. The other 36,000 btu would come from the strip heat at a cost of about $0.52/hr, total cost to heat is $0.67/hr.
    Using gas, 90% efficiency, I need 60,000 btu/hr in, at a cost of $0.66/hr. So by my calculations, at any outside temp above 0 deg F, it is cheaper for me to heat with electric backup than with gas.
    -jim-
    I don't know
    Quote Originally Posted by Daltex View Post
    Heat strips are always 100% efficient.
    A heatpump with a COP above 1 will always be more efficient than a furnace.
    Max furnace AFUE = 95%
    Efficiency is not to be confused with capacity or cost of operation.
    I don't know
    Oct 2008
    Indianapolis
    One other thing to consider is...Does your current electrical panel have the capacity to handle electric strip heaters. If not upping the capacity would be an additional expense to factor in your decision making.
    I wouldn't think Indianna would have many house that need a 4 ton heat pump for cooling, and only a 60,000 BTU furnace for heating.
    Oct 2008
    Indianapolis
    Orginal poster did not give square feet of space to be conditioned or if a load calculation was done. I live in central Indiana and am heating and cooling 6400 square feet with 4 ton of A/C and a +90% gas furnance. Load calculation's where done.
    Quote Originally Posted by Indy View Post
    What size is your furnace.
    Oct 2008
    Indianapolis
    125,000
    125,000
    Ok.
    My point was, he was trying to calculate operating cost.
    Using disproportional sized equipment.
    He is comparing a 4 ton HP, to a 60,000 BTU furnace for operating cost.
    Oct 2008
    Indianapolis
    I agree 100%.
