Results 1 to 9 of 9
    How to measure CFM?
    I am conditioning my crawl space and local code is to open a vent on the HVAC in the crawl space. I noticed that there was already a vent down there. The code is 1 cfm for each 50ft2 of floor area, so I need 18 cfm coming out if the vent. Does anyone know how I measure that?
    Western NC
    This is not a DIY site.
    Call your local contractor to come look at your crawlspace and determine the best solution to your situation
    East central Indiana
    That seems like a VERY bizzare code that would be nearly impossible to enforce.
    How many building inspectors do you know who are capable of doing CFM analysis???
    From talking with the city today, it is more like a recommendation that anything else.
    Western NC
    Quote Originally Posted by timchi29 View Post
    And from talking with us...its more of a recommendation that this type of work be performed by a professional that understands how to measure CFM, how to adjust CFM, and more importantly, knows whether or not this type of action needs to be done.
    Easier said than done. One contractor said that they need to replace the duct work then they can get an accurate # and then another said that they would have to rent the equipment, which will require a down payment. Amazing what HVAC contractors can think what they can get away with if you let them.
    You do know, you're speaking to HVAC contractors, don't you? Catch more flies with honey, than vinegar.
    Madison, WI/Cape Coral, FL
    Even good ducts leak more than that. Expect a 8-10% leakage on good ducts. 3 ton a/c has 1000 cfm of flow or 80 cfm of leakage. Thats more than enough. Plastic on the earth and seal the outside vents to keep the moisture out. Monitor the %RH and if %RH exceeds 60%RH, get a good dehu like Santa Fe Compact. For monitoring, check out the Accurite remote %RH meter from Wal-Mart or thermastor.com for about $35. Regards TB
    Thanks Teddy. I am actually getting 4" of concrete installed today to seal from the earth.
