    Red face Aprilaire 600A Control Wiring
    Hi guys, I'm new to the forum and hope you can help me solve my problem. I installed an Aprilaire 600A bypass humidifier and am having trouble with the automatic humidistat controller.I wired it exactly as the manual instructs but I can't get the solenoid valve to open. Terminal R and C are wired to a steady 24VAC. Terminals W/G and Cf are wired to a switched 24 VAC source via a transformer connected to the furnace accessory terminal(HUM).Terminals ODT are wired to the outdoor sensor. Terminals H are wired to the solenoid. When furnace is running I placed controller into test mode and can hear the relay pick up but there is no output volts (0.0 VAC) measured at terminals H. I do get a closed contact action across these terminals.If I switch the controller to manual with the manual resistor connected I get a steady 24 VAC across terminals H. Is controller defective or can I just wire a 24 VAC source in series with the H terminal and the solenoid?
    Nov 2008
    Valparaiso, IN
    Dry contacts
    Although I used this forum quite a bit as a service tech years ago, I haven't used it in the several years I was in distribution management, I have just come back to it as a contractor and understand that to discourage DIY, they do not want these discussions taking place here. From my memory, I believe those terminals to be dry contacts unless you flip a switch on the humidistat board. Check your instructions again.
    Thanks, CK Heat
    Smile Fixed
    Thanks ck heat, you were 100% on the money. The AB switch was in B position.
    Needs to be in position A. When it was in B position I read a phantom 24VAC on terminals H due to high impedance voltmeter (Fluke 77). Not real voltage. System works O.K. now. Thanks for your help.
    Jun 2001
    Louisville, KY
    Quote Originally Posted by ckheat View Post
    Thanks, CK Heat
    Do not provide DIY assistance.
    Consider this your freebie.
    Merry Christmas
