    Hmm the style of Carrier 19 series shims
    Anyone repair the Carrier centrifugal chiller. He should be know a shim pack under the impeller. This shim pack have many pcs. of aluminium sheet (0.0002" per pc.). It is very easy to remove from the shim pack to let you very easy to adjust the thickness of it. Who know the correct name of this shim style? I want to find this style shim to repair the water pump, because it is very easy to adjust the thickness!
    Regards
    Can
    N.E. IA
    I know exactly what you're talking about, but it never occurred to me to use them anywhere else but on 19D's.
    "Wheel" mechanics work on "Wheel" chillers
    South Jersey
    Don't know about 19D shims.....................
    But these have allways worked fine for me, on pump alignment jobs......
    http://www.metalshims.com/store/ms_p...himpack_A.html
    You can get them at Graingers, McMaster & Carr or any industrial supply house.
    Aug 2000
    Austell, Ga.
    The "Peelable" Aluminum shim stock is available from McMaster-Carr in thicknesses from .006" to .250" with either .002 or .003" shims.
    A 24" x 24" will cost you from $8. for .006" up to $260. for the .250" material.
    I do Luv' dem' Mcmaster guys....
    Ain't "None" of us as smart as "All" of us..
    Smile
    Quote Originally Posted by RichardL View Post
    Thank you very much! I find some supplier now!
    Can
