    Windsor ON Canada
    Help with McQuay touch screen
    Is there a procedure for calibrating the Microtech II touch screen. The touch part of the screen is off a bit. Presently I have to touch the screen about an inch above the area that I need to, to get a response. Also would like to darken up the letters on the unit and compressor controllers. I searched the McQuay site and IOM manuals and could find no literature on this.
    Oct 2008
    Honolulu, HI
    Confused McQuay
    I do not blieve there is a standard option available. Is the equipment still under warranty? If so, I would just call your rep to fix the problem?
    Aug 2000
    Under my tree
    Yes, it is easy to calibrate. You need the tech pw to calibrate it. Takes under a minute.
    To much work with too little time!!!!
    Windsor ON Canada
    Quote Originally Posted by absrbrtek View Post
    Thanks Abs, I will be back at the site on monday and give it a try. The only calibration that I could see was the buttons to the bottom right of the screen....but they all seemed to only deal only with the video. I will see what opens up with the tech password.
    Aug 2000
    Under my tree
    Been awhile, I think you gotta double press the button.
    Quote Originally Posted by hw chiller man View Post
