    Jun 2008
    Fireplace cleaning
    Work for a company that does mostly new housing they just started installing fireplaces about 3 years, i went to do SMC on a couple of them and the homeowner's decided that they did not like were the logs were sitting so they changed them and of course the whole unit turned totally white because of this. So i clean the glass with glass cleaner, vacuum of the logs and reinstall them the right way and then i try to vacuum and wipe the white junk off the inner chamber but no matter what i do it never comes back to its original black finish was wonderin if anyone knows anything that will bring the original black back, any suggestions would be appreciated, thanks
    High temp. black paint. :-)
    Seriously, the glass should turn black from soot when the logs are out of place.
    Feb 2007
    Northern Ontario
    Talking stupid homeowners
    sounds like moving logs caused hot spots in fireplace burning paint off....like the last guy said stove black make sure pilot is off ....... cut off homeowners hands....
