    Oct 2008
    Honolulu, HI
    Confused Coil Connections
    First of all I would like to thank everyone for this site. This is absolutely an amazing site and such a powerful tool as I strive to learn the industry.
    I have a question I've been pondering as I do take-offs.
    I'm looking at the Carrier submittals/product data for newer ACCU and looking at the coil connections. For the one I'm looking at - it lists Suction = 1-5/8 and Liquid = 5/8. Are these sizes on the submittal sheet in Nominal Dia. or OD? If OD, I assume to connect 1-1/2 and 1/2 respectively Nominal Dia. Copper piping to the coil?
    Thank you so much in advance.
    OahuDave
    Freon - air condition world -- OD dimension
    Oct 2008
    Honolulu, HI
    Coil Connections
    Mahalo!
    Feb 2007
    Northern Ontario
    Talking different thickness in copper be careful
    refrigeration air conditioning pipes are thcker... nitrogenized or made clean... plumbing pipe not as clean not as thick refrig costs more but will hold out in long run... cleanliness in our trade is mandatory that said water is our enemy it will csrew up everything....good luck
    Feb 2007
    Northern Ontario
    Talking sorry forgot something
    TYPE K and L for refrig and Airconditioning.... the size of the pipe in the coil or at the outdoor unit dont necessarilly mean you pipe whole system that size..check for unit specs... sorry if you already knew this stuff just thought id help if I could...
