Results 14 to 26 of 27
Thread: LON .XIF file
    The domains are the same however here is the other info
    under the device Hardware tab.
    Manufacturer: Mitsubishi Electric Corp.
    Device Class: SPIDDataFile Error
    Device SubClass: Network Management
    Transceiver: TP/XF-1250
    DSN1: 37/01/01
    XIF Present: False
    Why error by Device Class?
    Is the transceiver correct?
    Any suggestions?
    NY
    It does look like the transceiver is the problem. My guess is that the NAE is FTTP-10. The baud rate is much higher on the TP/XF-1250. That is generally used for backbones or high speed network channels. Does the NAE have 1250 capability?
    Quote Originally Posted by dapper View Post
    I don't think so but Can I change the 1250 in Lonmaker or
    is the transceiver specified in the .xif file
    Hampton Roads, Virginia
    Quote Originally Posted by mechinc View Post
    The transceiver is hardware, normally it can not be field changed. You probably need to get a TP/XF 1250 to FT-10 router.
    Kevin
    "There is plenty of room at the top because very few people care to travel beyond the average route. And so most of us seem satisfied to remain within the confines of mediocrity." -- Benjamin Nnamdi Azikiwe, first president of Nigeria
    "It's not the customer's job to know what they want." -- Steve Jobs
    The Mitsubishi board has a FT-10 chip in it.
    NAE needs FT-10 communication.
    Load the .XIF file and it shows up TP/XF-1250
    in the NAE.
    Used Echelon tool to look at the .XIF file
    and TP/XF-1250 shows up in the .XIF file.
    Called Mitsubishi tech support and they claim
    they only have one .XIF file for this unit and
    it is FT-10 communication.
    They sent it to me but still same issue.
    Any suggestions?
    New Castle, DE
    Quote Originally Posted by poochz View Post
    The LNS tool can commission without a xif, but the NAE requires one. The easiest is to use Nodeutil to connect to the device and generate a xif file. Then just add the xif to the NAE as a resource.
    Nodeutil182 I believe is the latest, available free from echelon's web site.
    poochz
    Try to get the xif from the device
    Tennessee
    Talking
    I agree with poochz and outofcontrolman you sould not even attempt an integration without nodeutil. once you understand how it works and you will never understand how you got along without it. Just because somebody from the manufacturer sends you an xif doesn't mean it was the right one, if you generate it yourself then there is no question. Anyway its free!!! and you can show off to your friends look how smart I am works great on the chicks too huh!!!!
    Jul 2014
    Hello!
    Our NAE 5520-1 was broken. We replaced by NAE5520-2. But after loading the backup we not seeing LON devices. I undestand that i must commisioning my new nae. But i can not do it, because Lon Marker wantes .xif file for Nae. How do i do it correctly?
    Pacific Time Zone
    In Lonmaker commission and upload from device
    Jul 2014
    I have an error after i have uploaded from device. What is wrong?
    " The new program interface does not match the previously defined program interface (subsystem: Ns, #59)
    Pacific Time Zone
    Something changed and the program ID's don't match up. I don't work with NAE's but something caused the program to change. Possible the NAE model? One would think they would allow it to retain the program ID for replacement purposes....Did you make a change to the programming/original file?
    Jul 2014
    Model Nae has changed, because our old model do not make on the factory. Buckup file (from old NAe model with configuration ) was loaded to the new NAe.
    Jul 2014
    I forgot to send pictures.
