Results 1 to 13 of 27
Thread: LON .XIF file
    LON .XIF file
    Performing a Lon job with a Mitsubishi split system going back to a NAE.
    I do not have an .xif resource file.
    How can I upload the .xif file to put in the NAE as a resource file?
    Pacific Time Zone
    What is your network management tool?
    I am familiar with Lon and Lonmaker, but not with the NAE.
    I have the latest Lonmaker
    Pacific Time Zone
    Drop a generic Lon device on the drawing from your lonmaker basic shapes stencil. Choose your interface type - FT-10/whatever it is and make sure you have a channel of that type on your drawing. Name it and then choose upload from device on the .xif file. I've always then service pinned the device to get the NID. Anyway once it's done commissioning you can then drop a function block referencing your new device and make connections.
    May 2005
    North America
    Nodeutil
    The LNS tool can commission without a xif, but the NAE requires one. The easiest is to use Nodeutil to connect to the device and generate a xif file. Then just add the xif to the NAE as a resource.
    Nodeutil182 I believe is the latest, available free from echelon's web site.
    poochz
    There is a way that seems good to man, but in the end leads to death.
    I will try and let you know....
    Thanks!!!
    Started to do your suggestion but then I received
    the Mitsubishi CD with the .XIF file on it.
    Loaded the standard and the device.xif files in NAE35 Lon
    as resource files.
    Rebooted NAE.
    It found the device but when I try to discover
    points, the NAE locks up then reboots.
    NAE version is 4.0
    Any suggestions???
    Seattle
    Did you build a LON network? You should be able to see both devices online thru your LON interface.
    Mar 2006
    Quote Originally Posted by mechinc View Post
    as resource files.
    Rebooted NAE.
    NAE version is 4.0
    Any suggestions???
    That sounds like par.
    New Castle, DE
    See: http://cgproducts.johnsoncontrols.co...t.aspx?CID=34#
    In addition, the LONWORKS network integration requires two standard resource
    files named STANDARD.TYP and STANDARD.FPT. The final required resource
    file is the default NV Configuration Data file. This required resource file, in a
    default state, is automatically added to the NAE resource file list when adding the
    LON Integration object. This default file must be updated with the actual installed
    configuration data by sending the LONWORKS network image to the NAE from
    MCL Tool
    New Castle, DE
    You need to also set the NAE and devices on the same domain!! Do this with a lon managment tool.
    Quote Originally Posted by CascadeControl View Post
    Yes, the lon network is built and I can see points in the field from Lonmaker.
    I cannot discover the points in the NAE.
    Quote Originally Posted by OutOfControlMan View Post
    I will check tomorrow!!!
