    Home is Azle Texas, work in Dallas-Fort Worth & surrounding areas.
    LONG RISERS FOR MINI SPLIT CONDENSING UNIT
    Slim Duct used to make a 4" riser for mini split condensers that was 78" long,
    that item is no longer available.
    Who knows where I can find such a critter ?
    Sounds kinda weird I know, but the request has been made for me to find them again. I need a couple of them at least 6" long.
    Can not use treated 4X4 's .Must look nice for the customer.
    Life as an adult is much like life in kindergarten - If I make it through the day without crying or hitting some one, then it was a good day!
    Nov 2007
    I use equipment rails for ductless split CU's. You can get them at Graingers as well as other vendors.
    http://www.grainger.com/Grainger/cat...rails-roof-top
    Is this a roof mount or at grade?
    Thanks for the response.
    Roof mount, on the white fabric type material.
    Had thought about the metal ones suggested, but cosmetics come into play on this job.
