    Setting up Mr Slim
    Hi all,
    I have a Mitsubishi Mr Slim, model MSY-A24NA, installed in a computer room. I'm having trouble getting it to regulate the temperature correctly. What's the best way to set it up so it maintains a constant temp. It's working but the temp is at 70 degrees and I don't need it that cold in there. If I raise the temp on the wireless remote, it still stays at 70. I guess I need to know how to set it up including vane, fan, mode, etc.
    Metro ATL
    Does the remote work properly for controlling other functions? Sounds like a communication problem between the remote and the unit.
    I think the remote is working. Just not sure the best way to have it set up. Right now I put it in "I FEEL" mode but still can't figure out how to raise the temp.
    Yuma, Arizona
    Your best bet is to locate a owners manual. It'll help you with your problem. And if for some reason your still having dificulties you can find a tech support number in the manual.
