    New Jersey
    Metasys OWS Trend export NCM
    How do I export trend data from an OWS to view the data in excel or a text file? System running OWS 12.0.
    Sep 2006
    Alaska
    Copy and Rename
    Not sure where your system stores the trend files. If you can locate them, copy the files and rename them to a excel extension .xls
    Law Of The Thermostat: He who has the thermostat wins!!!!!
    From the Start menu select "printers and Faxes"
    Select "Add a printer"
    Select "Local" printer
    For the port select: FILE: (print to file)
    For Manufacturer select "Generic" and for printer "Generic / Text Only"
    Give the printer a name
    Make this printer your default printer
    On the OWS run your trend report. When the report is finished select "Item..Print" .
    Because your default printer is the printer you just created, you will be prompted for a file name. Give this name with the complete path and give it the "txt" extension. eg C:\MyReport.txt
    You can open this file in Excel
    NW Ohio
    Go to:
    or see attached pdfs
