Thread: Looking for fireplace doors....
11-19-2008, 09:57 AM #1
- Aug 2007
- 171
The problem I am running into is that my opening is 43 1/2"(W) by 31 1/2"(H). Can anyone recommend a good place? Thanks!
11-19-2008, 06:13 PM #2
proper doors
If your fireplace is of masonry construction, you can order custom doors if need be through most any stove shop. If you have a factory built fireplace, you can only use the doors tested and listed for use with that specific model fireplace.
Aftermarket doors on factory built fireplaces generally restrict the airflow into the fireplace thus changing the thermal signature of that unit. All the testing and listing goes out the window when you cannot predict performance.
HTH,Keep the fire inside the fireplace.
11-20-2008, 09:19 AM #3
- Aug 2007
- 171
Any online places that you recommend to purchase them?
