Results 14 to 26 of 27
    Oct 2008
    Charleston, SC
    why would you go that route? not always true. easiest way to tell is turn heat up all the way and go pull disconnect on outdoor unit. if you got warm air coming out then you have heat strips....looking at meter? what if water heater or anything else in house happened to turn on?
    Nov 2000
    Eastern PA
    Quote Originally Posted by jimj View Post
    Been thats not always true. His model ARUF030-00A-1A indicates no strip,But you can order with factory strip and it would have a model number like ARUF030-05A-1A. The 05 would indicate 5 KW of factory strip.
    No you can't. The ARUF air handlers do not come with factory installed electric heaters the way the older A series did. It is a field only installed feature.
    Actually, let me clarify; this feature is available for very large quantity orders of air handlers for specific large complexes where the heaters can be installed at the factory for special job quote applications.
    ...seek, and ye shall find;..
    Ecclesiastes 10:2 NIV
    Nov 2000
    Eastern PA
    Quote Originally Posted by Paymemore View Post
    You think that going outside and pulling a disconnect is easier then setting the thermostat to EMERG. HT? Well, ok; whatever rows you boat.
    Alabama
    Quote Originally Posted by RoBoTeq View Post
    People try to make things so complicated, don't they Robo?
    Aug 2008
    Tell the wife to turn the emer. heat on not the hot water.
    Alabama
    Quote Originally Posted by mike robinson View Post
    You've got us all beat. You're the man. You've got enough posts. Apply for pro membership. You'll be able to help ALOT of people on here!
    Nov 2000
    Eastern PA
    Quote Originally Posted by BamaCool View Post
    Well, I know that I am not one to make things complicated. I have heard many people refer to me as being "simple"
    Alabama
    You simple?? Mike Robinson has simple figured out. Look at the meter and don't turn on the hot water! 4500 watts vs. 10'000. Now that's simple!
    Nov 2000
    Eastern PA
    They may have been referring to my mental capacity
    Nov 2000
    Eastern PA
    Thanks for the heads up.
    Oct 2008
    Charleston, SC
    Easier then bouncing back and forth making sure its on, and assuming the wheels spinning for you. seems to me best solution is always the sure fire way. then assuming what it is you did is causing it to spin faster. short cuts can get you in trouble pretty quick in my experience....
    Nov 2000
    Eastern PA
    Sorry. I was referring to the poster who said to set the t-stat on emergency heat and turn the temp up. That would lock out the heat pump and turn on the electric heaters. All done from the comfort of the thermostat
