Results 1 to 13 of 27
    Oct 2008
    Not sure if I have emergency heat...
    I have a Goodman CPLE24-1C heat pump and a Goodman ARUF030-00A-1A air handler. I need to know whether or not this setup has emergency (or auxiliary) heat? I've checked the company website and have found nothing that helps me out. I need to know because I am wanting to buy a programmable thermostat. The models that work for heat pumps with emergency heat are significantly more expensive than ones that operate heat pumps without emergency heat. Any help is appreciated.
    Thanks!
    Emergency heat. Is not part of the air handler package itself.
    It is a field installed option.
    On your current thermostat.
    Set it to emergency heat, turn teh stat up.
    If it comes on, and you smell something getting hot, like dust, or feel air that is much warmer then in heat mode.
    You have emergncy/aux heat.
    Alabama
    The air handler does not come with E-heat. The installer adds it. You have a 2 ton outdoor unit with a 2.5 ton indoor unit, which is common, because alot of mfgr's use the same A/H with 2 - 2.5 ton units. I would think you have 10kw strip heat, but to know for sure you need to contact the installer and ask which strip heat kit was installed.
    Alabama
    Sorry Been, you type faster than I do.
    Aug 2008
    not sure if i have electric heat
    Here is another way I think you can find out depending on your elect. meter have some one set the uinit to emer. heat watch the wheel in your elect meter to see if it speeds up if it does you have strip heat.
    DC Metro Area (MD)
    Quote Originally Posted by mike robinson View Post
    And boy does it start spinning fast.
    Virginia
    a good installer will mark the data placard if and what size the strip is . also call your installing contractor and have them install you a thermostat and a outdoor thermostat to keep the strips locked out till balance point is reached they should have that info
    Jan 2006
    Hangin out with you losers
    How big is the wire going to your A/H?
    I remember my first day,It was fun!
    Is this a DIY install?
    Arizona
    Been thats not always true. His model ARUF030-00A-1A indicates no strip,But you can order with factory strip and it would have a model number like ARUF030-05A-1A. The 05 would indicate 5 KW of factory strip.
    Make your expertise uniquely valuable.
    Make your influence uniquely far-reaching.
    Oct 2008
    Yes.
    Oct 2008
    Thanks. I did your test and it appears that I do have emergency heat.
    Alabama
    Excellent advice
    I don't know why I didn't think of that. Stupid me was just thinking that if you put on E-heat and felt warm air coming out, it must have heat strips installed. Damn, the ol' power meter thing got me again!
