Results 1 to 12 of 12
    Nov 2002
    NJ - WORK IN NYC AREA
    Question SELECTING A LOCK OUT RELAY
    Need info on how to select a lock out relay?
    Obviously in a control circuit with a LP and HP control, there is a race due to least resistance.
    Can anyone guide me towards a site on how they calculate this relay coil?
    I don't tink its as simple as e = r x i??
    "My hands are for sale"
    Jul 2005
    south
    RBM relays p/n 90-109(24v) and p/n 90-110(230v) are made just for lock-out relay purposes.
    BC,Canada
    Not sure how they calculate it but i think the formula is:
    E (voltage)=I (amperage) x Z (impedance)
    High impedance lockout relay coil ends up in series with contactor coil or other load,reduces the current flow enough that the contactor coil won't pull in.
    The Great country of Texas
    You can go to Trane and get a "reset relay" out of one of there older recip chillers (CGAA). It is a high impedence coil when put in series with the contactor, it produces enough voltage drop to keep the contactor coil out.
    I personally hate them. I would rather use manual rest switches so I don't have to guess. Old and Lazy!
    "I'm from Texas, what country are you from?"
    One other thing, I am assuming you do not have pump down using the low pressure switch. If so, it will lock out every time it pumps down.
    North Florida/South Georgia
    In a pinch
    You can use a 90-380 or a 90-381 depending on your coil voltage.
    We carry a "limited" selection of parts & these relays are perfect because they will dub for a variety of applications.
    All my leon freaked out!
    Nov 2002
    Thumbs up
    Thanks guys.
    I'll record the relay part numbers. Abco supply should have them.
    Jan 2010
    Central Florida
    stickerhead: Do you know any company that makes a manual reset LP switch?
    "Give a man a fish he eats for a day. Teach a man to fish he eats for a lifetime"
    Nov 2002
    Smile
    Johnson Penn
    P20BA SMALLER CONTROL
    P170B LARGER FULLY ADJUSTABLE
    Both fully adjustable.
    Apr 2006
    mechanical room
    anyone have a wirinng diagram of a lockout ralay, havent seen one in so long, i know the lp, hp and lockout relay n.c. switches are in series, i forgot where the coils are placed in the circuit
    Jan 2010
    Central Florida
    TitleLess posted this picture on another thread. Its also the one I used when I had a brain fart and couldnt remember how to wire one. One thing I am working on tho is if it locks out on LP that it will reset the lockout when the T-Stats shuts off the demand.
    State of Confusion
    Quote Originally Posted by stickerhead View Post
    those work good if your looking for a 110 volt relay.
