Results 53 to 58 of 58
Thread: Controls In General
10-28-2008, 11:44 PM #53
Yep that would be one way to integrate. Though a jace would be better as someone else already stated.
A way to think of that for those learning here about integrating 2 different types or brands of controllers.
Its kinda like a Mac talking to a PC via an internet connection, the browser (or the plugins attached to the browser ie Java) becomes the interpreter between the 2. Probably not the best analogy but it should helpBuild it and it will break. Fix it and it will work. Ignore it and will cost more. Patch it and it will get worse. Cross the bridge before the flood.
10-28-2008, 11:45 PM #54
To be fair, the question was: Does any other bacnet manufacturer use ARCNET other than ALC?
of the 82 listed, if you narrow it down to Building Automation/hvac controls, the list gets shorter:
andover
automated logic
cimetrics
johnson controls
teletrol systems
Trane
however, if you look at the list from the wayback archive(1997), it is almost the same - except automated logic was not listed then - late adopter?
http://web.archive.org/web/199706090...om/example.htm
10-29-2008, 06:51 AM #55
Permanently Removed
- May 2002
- 9,564
Even those left is simply a formality because tell me who is integrating bacnet multi-vendor across ARCNET? However, I can understand why ALC wants to use it. It is deterministic. So, when you have Mr. unreliable MSTP by comparison I can see why you want the ARCNET... if you aren't using a a more modern and robust field bus.
10-29-2008, 03:09 PM #56
- Dec 2005
- California
- 227
Isn't Bacnet MS/TP 76.8 the most common format? Sysint?
10-29-2008, 03:17 PM #57
Permanently Removed
- May 2002
- 9,564
I think maybe bacnet/IP is most common now. Do you really achieve 76.8 or is this simply a max setting?
History: My question was specific to the ALC lineup and why they use ARCNET. Xarulu wanted to suggest that LON had a single chip maker (Echelon) FALSE and wanted to suggest this was more proprietary than his ALC lineup, which is why I brought up ARCNET because even the bacnet guys complain about this... (see previous)
Anyway, I understand why ALC would want to use it over MSTP. It would be more reliable.
10-29-2008, 08:01 PM #58
CO2 Racks Rock !
