Results 1 to 13 of 18
    Jun 2008
    BIG BANG - FROM HOT WATER PIPES
    A new heating system was installed in my duplex.
    Our main floor has a hot water 20 Kw Electric Hydra boiler and our second floor is only electric baseboards.
    We originally had hot water oil furnace.
    The problem is from our main floor with the hot water electric boiler. Every time it turns on there's this loud bang that comes from the pipes of the baseboards.
    What can be the problem? Is this safe? We already called the technician.
    You'll need the tech to find out what it is for sure.
    Looks like 2-¾" return lines, and 1-¾" supply.
    That can give you some hammer noise.
    Massachusetts
    Looks like 2-Ύ" return lines, and 1-Ύ" supply.
    Been, how'd you see those attachements? All I see is an empty box that says there's attachments but nothing in it.
    Jul 2001
    Gold Coast of Connecticut
    I see them fine
    Aire Serv of SW Connecticut- Gas heat, dual fuel and central a/c systems installed and serviced
    Cedar Grove, Wi-Sheboygan
    Sounds like water hammer, nothing compared to a 6" water line form a fire hydrant busting, LOL !!! We used to do that once a month without fail here in town. Villiage guys didn't like us to much
    Oct 2008
    Bethel Park, PA
    I can't see them either. A couple of other posts too. I checked other posts and I can see them. Whats going on??
    Aug 2008
    Big bang from hot water pipes
    My computer won't even let me click on it at all it just shows a slash mark .
    Aug 2008
    Just got alook at the first picture never could get the second one to load anyway back to your problem looks like you have aexpansion tank need to know if the cir. pump runs all time if not the hot water will hit the cold pipes causing them to expand guess what something got to give end results is alound bang.
    arlington, tx
    its hard to tell from the pic but it looks like you have 2 way valves. they take a while to open so if your pump comes on instantly it will cause hammer
    Quote Originally Posted by skippedover View Post
    I don't know.
    I just can see them.
    Usually, I'm the one that can't see them.
    Jun 2008
    Thanks for ur help. I have re-posted the images and added 2 more pics.
    I appreciate the help and will give the info to the technician if he ever bothers 2 show.
    I have to tell you that this is just not a bang but sounds more like one big explosion every time the heat turns on.
    the main floor has an upstairs and a downstairs if that matters.
    Now that you added. I don't see them.
    Jun 2008
    4 attachments i see them all.
