Results 1 to 13 of 16
    Oct 2008
    HVAC Doesnt work after trying to replace thermostat
    I recently bought a new thermostat at home depot, it is a generic, one size fits all. I followed the directions and connected the proper wires. It didn't seem to turn on after that. So reconnected the old one the way it was and nothing. Then i checked the breaker outside, and nothing. Then went in the attic and opened the access panel on the unit( its a Payne horizontal heat/air, 1989 house) and looked for a fuse somewhere in the unit. Next i tried the self test feature and i got nothing. What could be wrong I checked everything i thought was wrong.
    Oct 2008
    Bethel Park, PA
    Boy,
    How many times a day do I hear 'My thermostat must not be working. I set it for 70 and it is 55 in here now.'
    somewhere between heaven and hell
    I can't tell you step but step by did you turn off power to furnace before you installed new stat?
    Oct 2008
    ya there was a plug next to the unit in the attic, i unplugged that before continuing.
    You let the magic smoke out. The only ones that can put it back in are pros. Call one.
    Aug 2008
    [QUOTE=the dangling wrangler;2024387]You let the magic smoke out.
    I hate it when that happens.
    Jan 2002
    Ft.Worth,Tx
    Lightbulb Great Job...
    The self test circuit is blown, call for assistance at local service company.
    'Life begins with the journey each day'
    Dec 2006
    Middle Tennessee
    Quote Originally Posted by EvanPMeth View Post
    ya, you burned it up!
    Time to call a service tech, and see how much damage you did.
    This generation of the "we can do it ourself" gives our industry more easy work fixing homeowner screwups than simply installing a new thermostat would have. I know the discovery channel or whatever tells you how easy it is, but you are about to find out that the money you saved just got spent twice. Good Job!!!! once to install the stat correctly, and once to fix your screwup.
    Screen name of EvanPMeth. Hmmm. Wonder if that means anything?
    Quote Originally Posted by the dangling wrangler View Post
    ROFL
    ROFL
    Well, looking at the time of the original post, I'm thinking it just might. But, I guess I replied at an odd hour of the day too.
