Thread: NG fireplace
10-24-2008, 03:43 PM #1
NG fireplace
hello I'm interested in buying a NG fireplace from my father in law but I would like to know what all is involved in switching it from Ng to LP
Knowledge comes with experience
10-24-2008, 07:25 PM #2
- May 2005
- Madison, WI
- 1,078
You get a LP conversion kit from a dealer who sells that brand of fireplace. Preferably you should have them install it and do a full inspection of the unit also.
10-25-2008, 05:00 PM #3
- Feb 2007
- Northern Ontario
- 128
let the pro do it
you may rquire new orifices in pilot in main burner and new spring in gas valve.... a pressure test on manifold should be done after all parts installed to insure proper setting..
10-25-2008, 05:15 PM #4
Conversion to LP is not a big deal at all, as far as the fireplace itself. If the gas plumbing to the fireplace is already figured out, no worries.
10-26-2008, 03:05 PM #5
I knew that you had to change the orifice and set the gas valve but i didnt know if you had to change the gas valve
10-26-2008, 03:29 PM #6
when manufacturer will give you the info on what needs to be done, just like anything else..
