Results 1 to 8 of 8
Thread: RTAA Service Bulletins
10-24-2008, 08:04 AM #1
- Jan 2001
- 79
I would like to fine the web site that has all the service bulletins for the RTAA 125 chillers. Have looked but have had found any. Thanks
10-24-2008, 11:26 AM #2
You have to be employed by trane or have friends in low places.haha
10-24-2008, 12:21 PM #3
I think the one your looking for is RTAA-SVB07A-EN.
I don't have a scanner. I'm low tech. Maybe Jay Guy will read this and scan it for ya. Maybe your local trane office will give you this Service Bulletin. All you can do is ask.
10-24-2008, 04:24 PM #4
You may have better luck by asking about a particular problem or issue that you need a service bulletin for to do some troubleshooting for . That is better than asking for everyting .
Whooo Hooo spring at last , time to get the toys out ........vrrrroooooom !!!!
10-24-2008, 11:39 PM #5
ALL service bulletins are usually not necessary. a lot of trane service bulletins are repair issues that pertain to a small group of units...you either have that unit or not. if you have it, you fix it and then the service bulletin is pointless for that unit. in some cases, it is a mandatory fix. the local office gets a list of serial numbers affected, most (probably not all) units are then repaired and then once again, the service bulletins are no longer needed.
some service bulletins are actually troubleshooting bulletins and those are keepers. however, most are very large and difficult to email sometimes. you may have better luck getting a copy from your local branch.
like graham said, let us know the specific nature and perhaps we can tell you what is going on as well as what service bulletin to go get.
good luck.The weak aren't destroyed by the strong.
The weak are destroyed by the under-estimated.
I know a famous song that ends in 'my nose'. The artist is dead. Know who?
10-25-2008, 06:02 AM #6
Any service bulletins that I get from Trane now come with a very specific warning about not sharing the SVB and not posting it online.
R2B4BTU
10-25-2008, 08:58 PM #7
10-26-2008, 04:59 PM #8
Professional Member t-bad email address
- Sep 2005
- chiller plant
- 49
