Thread: Three zone training room set up.
10-23-2008, 09:20 AM #1
- Feb 2008
- Purcellville Va.
- 652
I have a tenant with a good sized training room with three zones.
A 5 ton cooling only DX split system and three zone dampers. The system was controlled by an old Carrier Monitor master stat and two slave stats.(Master stat is belly up)
I am looking at replacing everything and installing three Distech EC-STAT-FC-AC and three Belimo modulating (0-10vdc) actuators. Do you see any problem with having the Fan / cooling output of all three stats controlling the same unit? basically a call for cooling on any one stat will bring on the unit or do I need to have a master stat?
Thanks,
10-23-2008, 10:09 AM #2
Make sure you have the min airflow for the DX. Doubt you want to run the cooling if only one zone is calling.
10-24-2008, 06:30 AM #3
- Mar 2008
- Baltimore
- 50
A more expensive solution, but one to consider in the future is a VVT system. Adding a bypass duct and bypass damper with pressure control will allow the unit to run when only one zone calls for cooling without starving the DX of the required airflow.
10-24-2008, 07:14 AM #4
- Feb 2008
- Purcellville Va.
- 652
Thanks for the input.
This system has a weighted relief damper that will allow excess just to pass directly back to the plenum so starving the DX shouldn't be an issue.
I have been advised that going with three EC-STATS is an expensive solution so I looking at doing it with a ECP-203.
