Page 1 of 4 1234 LastLast
Results 1 to 13 of 44
    May 2002
    AX device capacity
    AX capacity questions. I get differing explanations on capacity for LON devices on an AX box. Is this completely dependent on available resources or are there other considerations? For instance, does the box always consider all variables from a node or is more like the ilon100 where you pick the variables you want to deal with?
    I'd like to know a practical average of how many devices an AX box can handle.
    Also, can you leverage a AX to utilize IP852 or is this a lost cause because the box is limited?
    TIA
    NW Ohio
    Quote Originally Posted by sysint View Post
    TIA
    What are you up to now?
    May 2002
    I can guarantee you it is something...
    NW Ohio
    You must have lost your link to Niagara Central, so here it is.
    Niagara Central
    And here's something cool that's coming out soon. I hope Dear Leader will allow me to own one.
    98B
    Mar 2006
    TIA
    As of Revision 3.2 IP852 is a go.
    The white papers are at the bottom of the page.
    http://www.tridium.com/cs/library/ax_library
    May 2002
    Does the box have enough physical capacity to make use of IP852? I'm thinking it doesn't.
    May 2002
    Which kool-aid whitepaper talks about IP852? TIA.
    Mar 2006
    Hmm. Why do you say that? You need to define "Box" as well.
    NW Ohio
    Be careful, you're walking into a sysint mine field.
    He's not after info.
    He's thought this AX bash out 40 moves ahead.
    May 2002
    nothing like that on this one NINAX. I'm just assembling some practical information on the product. I used to play chess as a kid and about the farthest I would get is 6 moves in advance... so crediting 40 to me is quite the compliment. Thanks
    NW Ohio
    Never underestimate one's opponent. And I still say this is AX bash set-up, or at least you'll try.
    Why don't you start out by posting the ilon specs that you are requesting for an AX.
    Then expand on which platform & options the AX you want to try to bash should be.
    May 2002
    ...what's an ilon?
    "And I still say this is AX bash set-up, or at least you'll try." Nope. Absolutely not.
    May 2002
    Quote Originally Posted by freddy-b View Post
    I'm trying to understand their architecture and the capacity of each product in a Lonworks network.
