Results 1 to 13 of 313
Thread: Pulling a vacuum....PROPERLY...
10-21-2008, 04:32 PM #1
This is a little thread to show MY way of pulling a proper vacuum on a system and just how quickly it can be done.
This was an evap coil change out I did today. Lineset was disconnected in the basement for about an hour while I did sheet metal. The lineset was 30 feet long and I pumped this system down, so when the vacuum was pulled it was pulled on the lineset and evap coil only...
The total job took 2 1/2 hours.....here's the pics....
(sorry about some of the quality...my camera is not the best)
Pic. 1 - My pump set up....no manifolds needed...why would you want to pull a vacuum on them anyway??
Pic. 2 - The pump hooked to the unit....I use core removal tools to get the cores out of the way and also have a place ON THE UNIT to hook up my micron gauge. Why would you want to measure the vacuum anywhere else??
[IMG]http://i514.photobucket.com/albums/t...8124/Pump1.jpg[/IMG]
Pic.3 - Just before turning the pump on for the first pull....notice the time 2:09 pm and the gauge starts at 25,000 microns.
[IMG]http://i514.photobucket.com/albums/t...8124/Start.jpg[/IMG]
Pic 4. - 7 minutes and my gauge is at 200 microns.
[IMG]http://i514.photobucket.com/albums/t...24/200at10.jpg[/IMG]
Now I break this vacuum with about 2 psi of nitrogen and start the process all over again....
Pic. 5 - This is the second pull with the vacuum and I am now at 160 microns and have been at it for just 11 minutes...
[IMG]http://i514.photobucket.com/albums/t...24/1stPull.jpg[/IMG]
Pic 6 - Before the last pull, I break with nitorgen and put the cores back into the system with it under a possitive pressure so not to draw moisture into the system...I only need one hose to pull and my micron gauge at this point. Here is the set up....
[IMG]http://i514.photobucket.com/albums/t.../FinalPump.jpg[/IMG]
Pic. 7 - After ONLY 30 minutes I have pulled 3 vacuums on this system and after being off the pump now for 5 minutes.....here is my final reading....holding steady with no rise what so ever...
[IMG]http://i514.photobucket.com/albums/t...4/Finished.jpg[/IMG]
This thread is not to brag or to boast....I am not an engineer nor do I claim to be the best tech in the world...but proper procedures and proper tools will make all the difference in the world!!I need a new signature.....
10-21-2008, 06:18 PM #2AMEN to that!!!proper procedures and proper tools will make all the difference in the world!!
i still use two hoses on the last pull
well i overkill everything anyways lol
http://www.youtube.com/watch?v=nFl0n...ture=endscreen
10-21-2008, 06:37 PM #3I need a new signature.....
10-21-2008, 07:49 PM #4
lol it's a trane washed world around here, on the HP's i use the discharge port
i rarely pump a system down too.
worried about letting air in when disconnecting your micrin gauge, you put refer in while it is still atached to the system
i sure don't
10-21-2008, 09:26 PM #5
10-22-2008, 07:56 PM #6
Professional Member*
- Jul 2001
- Anderson,SC
- 893
Why can't you put the core back in while in a vacuum?
I do it on each vacuum, I use the field service valve tool.
STUD
10-22-2008, 08:00 PM #7
10-22-2008, 08:01 PM #8
10-23-2008, 10:41 PM #9
- Oct 2008
- So Cal
- 15
Nicely Done
10-25-2008, 01:51 PM #10
10-25-2008, 02:59 PM #11
10-25-2008, 03:05 PM #12
10-25-2008, 04:17 PM #13
- Jun 2007
- Greenville,North Carolina
- 1,903
By the way,good set-up/procedure.But you are not doing it right regardless because your not an know-it-all engineer.
Look to the past to learn;look forward to live.
Coach Dean E. Smith
