Results 1 to 13 of 26
    Aug 2008
    Diagnoses Please
    I have received much benefit and knowledge from reading replies to others no a question about a problem that spooked me since my house was built.
    We have Lennox furnace 15 y/o (installed Oct 1993) that's had a sooting problem from the get go. Its fueled by butane and runs from Nov-early April (deep south)
    This sooting has will cause the furnace not to fire unless the soot is removed-our builder's HVAC installer recommended using a hair dryer or vac on reverse to blow out the soot. Usually this had to be done monthly to keep it operating fine, yet the flames were never true blue (orange-yellow tinged)
    It always heated fine but just wondering if this problem was b/c we used butane for a system that had to been "adapted" from NG to butane.
    Any ideas
    Jun 2008
    Cincinnati, Ohio
    Time to replace the furnace. Seriously, though. A properly operating furnace will not soot. The soot is an indication of a very serious problem. Do not operate until a qualified service tech has given his blessing.
    Jun 2007
    The Twilight Zone
    Quote Originally Posted by AvantGarde View Post
    IWe have Lennox furnace 15 y/o (installed Oct 1993) that's had a sooting problem from the get go. Its fueled by butane and runs from Nov-early April (deep south)
    Butane? Wow.
    Aug 2008
    Quote Originally Posted by gary_g View Post
    Butane? Wow.
    What is "wow" No I'm gettin' a little worried
    burlington county n.j.
    sure its not propane?
    sooting is a serious problem, get someone else to look at it.
    SE Michigan
    I dont think I have ever heard of a butane fueled furnace....propane and NG yes, but not butane.
    Never heard of a conversion kit for this either.
    If it is butane, perhaps you have the wrong conversion kit causing it to soot.
    “Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery.”
    Aug 2008
    Its Propane, my bad. Tuff day @ work
    Quote Originally Posted by t527ed View Post
    new guy (one who shafted me couple of weeks ago) put a new 'nozzle' on a doo-dad that apparently put the PROPANE into the burner
    You mean a new orfice.
    Sounds like your furnace was never set up.
    Just the conversion kit installed.
    Then they turned the switch on, it worked and they said its good to go.
    You need someone to clean it, and then set it up properly.
    if it has been sooting for 15 years it's probably time for a new one.
    has anyone pulled the HX to wash it out?
    If they didn't use the proper conversion kit or set the manifold pressure correctly it could soot. If the orifices are not sized for propane and supply a "rich" fuel to air mixture it will soot. It is almost impossible to properly clean out a sooted heat ex. so it may need to be replaced. Get a competent tech to check it out before you operate it any longer.
    Aug 2008
    Been is correct new orifice
    and no it hasn't been cleaned. Waiting this weekend to fire it and we'll see.
    I DO know that flames would actually come outside the burner box and get that familar loud pop when the metal started cooling. I gonna depend on you guys for some answers, so appreciate all that's answered so far.
    N.E. Ok.
    I would advise you to not touch it and leave it off.
    Call around and make sure the technician who will be coming is aware of the ongoing problem i.e. sooting,roll out of flames and conversion done.Be sure to give the mod.#. Good luck and be safe.
    you have a mess there!!!
    time to find a qualified technician to work on your system!! for sure!!
    it amazes me how people do this kind of work and still make a living!
