    Jun 2008
    moisture drain to pipe even when heater is on?
    I had my Trane installed in August http://hvac-talk.com/vbb/showthread.php?t=178378
    just start to have heat on, everything seem to work
    but I notice the drain pipe continue to drain water not sure if that is suppose to happen? I know when A/C is on it pulls moisture... but does this also happen when the heat is on? By the way, it's not raining outside just a little chilly.
    I just happen to look at my sump pump when I notice the drip of water.
    just want to check with you guys before I call for service.
    90% furnace drops much of the flue gases below the condensing point so puts out as much water as an A/C running so you're seeing normal operation.
    yep. You got a condensing furnace. So you will have condensate.
    Apr 2008
    Alberta Canada
    Wink You Learn something everyday
    It will also depend on ambient temperature outside. The colder it is the more moisture it will produce.
    Do it right the first time.
    Jun 2008
    thank you for the reply guys. You have saved me a service call!
    I wonder if the little water that drain out is "warm" I guess there is just one way to found out. j/k
    thanks again!
