Results 1 to 13 of 25
    Cooling tower VFD Min Speed
    What is the manufactors min speed/HZ on a cooling tower fan motor rated for inverter duty. I was taught 20hz was min speed to keep from over heating. Engineer wants to run with no minimum.
    "Dying aint much, its living thats hard." (Josey Whales)
    Indy
    I set fan applications at 10 Hz and pumps at 18 Hz on the drives I set up. I've had no reported problems after ten years of factory start ups.
    If this cooling tower is belt driven, I wouldn't go below 6 Hz or 10%.
    If it is gear driven, you can't go below what the gear drive manufacturer recommends what the min. speed should be for proper lubrication.
    Aug 2000
    Under my tree
    Was told by Marley that at 18hz your airflow pretty much stops thru the tower. I run the tower water up to 2F below setpoint before sending the drive a run command. Starts at 18hz and goes from their. If it drops 4F below setpoint the drive goes off. The towers and drives I just installed run within
    .15F of setpoint and usualy closer to .04F.
    To much work with too little time!!!!
    The Great country of Texas
    Still did not teach you anything! 20HZ is safe but I would contact the tower box rep. Some of the boxes have a slinger for "splash" lubrication. Don't work so well at slow speeds. The motors require around 20HZ to get the fans on the rear to effectively cool the motor. TEAO might need more speed since they use ambient air over them.
    "I'm from Texas, what country are you from?"
    Aug 2000
    Under my tree
    LOL, that's what Marley recommended. Been online for a few 1000 hours with no issues.
    Quote Originally Posted by stickerhead View Post
    Dident learn anything from you 20 years ago when you was my supervisor why should anything be different today? Hhhhmmmm is it me or you???????
    Somewhere in the world.
    I would agree with the a 20HZ min. for that application , any new inverter start ups on pumps or ahu's I would set up for 15HZ to 20HZ and have had no problems at all.
    A mind is like a parachute. It doesn't work if it is not open.
    The best part of going to work is coming back home at the end of the day.
    Hard work spotlights the character of people: some turn up their sleeves, some turn up their noses, and some don't turn up at all.
    Quote Originally Posted by CaptJackSparrow View Post
    That's why you live out in nowhereville where no one knows what you are doing is right or wrong. That's why C-alvin made so much $$$
    Well thats what I like about it! I get to decide what is right and what is wrong! No corprate policy or little Hitlers! Its right if I say its right and wrong if I say its wrong. Like the little trip to "trailer hill", That was WRONG!
    Thanks for the replies. I set min at 15hz as the know it all engineer agreed to. Its his motor!
    Whoo! You just slapped my brain! I thought you would have wanted to have forgotten that! Bad mental picture but it was funny! I will see if C-alvin remembers!
    The question is not if you can remember but if can you forget!
    I was innocent but you and Tio wern't
