Results 14 to 25 of 25
    NW Ohio
    Quote Originally Posted by freddy-b View Post
    Ya, but its too late now..right?
    It depends on what went wrong. But if it was simply upgraded, it should downgrade just fine.
    BUT FOLLOW THE DOWNGRADE/CLEAN DIST INSTALL DIRECTIONS!
    DO NOT DEVIATE FROM THE INSTRUCTIONS!
    Or you will be boxing it up and sending it in for repair.
    Mount Airy, MD
    NINAX,
    I like your new avatar
    Mar 2006
    Quote Originally Posted by NINAX View Post
    How do you get back into platform now?
    NW Ohio
    That, I can't answer.
    Again, the license would just prevent a station from running. You should still be able to connect and see in the App Director, and it would say that the JACE is not license to run a station.
    That's why I'd do a dump and see what it spits out.
    Feb 2005
    Quote Originally Posted by Chris_Worthingt View Post
    The Jace is only as smart as its operator and it sounds like you jumped the gun
    The Trids might be able to help you out, get together the information you have and give them a buzz
    No question that I jumped the gun,
    but still say the Jace should have checked my breath, can't let a drunk do the upgrades,
    Mount Airy, MD
    There are ways to recover, BUT at this point it may be best contact the Trids and have them WALK you through this, Should you be able to recover out of this mess, you have lived and learned
    Serial Shell/Null Modem
    I would go into that bad boy through hyperterminal/Serial Shell mode.
    It may give you some information in the boot up. Boot Flash Errors and so on.
    "I wish it were winter so we could freeze it into ice blocks and skate on it and melt it in the spring time and drink it!"
    Feb 2005
    Quote Originally Posted by tk2k View Post
    This is through serial shell at startup:
    ----------------------TCP/IP Network Status------------------------------
    en0: flags=8c43<UP,BROADCAST,RUNNING,OACTIVE,SIMPLEX,MU LTICAST> mtu 1500
    address: 00:01:f0:80:47:58
    inet 192.168.0.5 netmask 0xffffff00 broadcast 192.168.0.255
    en1: flags=8c43<UP,BROADCAST,RUNNING,OACTIVE,SIMPLEX,MU LTICAST> mtu 1500
    address: 00:01:f0:80:47:59
    inet 192.168.0.6 netmask 0xffffff00 broadcast 192.168.0.255
    JACE-2 Base Board detected
    LON interface detected
    MESSAGE [15:24:21 20-Oct-2008] [tid=1] niagarad: starting, baja_home=/niagara
    MESSAGE [15:24:21 20-Oct-2008] [tid=1] webserver: web server started [tid = 4]
    MESSAGE [15:24:21 20-Oct-2008] [tid=1] station registry: starting
    MESSAGE [15:24:21 20-Oct-2008] [tid=7] app: starting watchdog thread
    MESSAGE [15:24:21 20-Oct-2008] [tid=7] niagarad: Communications_Inc start
    ing
    login: MESSAGE [15:24:35 20-Oct-2008] [tid=7] niagarad: Communications_In
    c exited with status 0
    sysmon: j9 is no longer running
    Talked to non-tridium contact, they say have to send it back.
    Waiting to see if I can talk to Trids directly before boxing it.
    Nov 2007
    Little Rock Arkansas
    Upgrade
    In the Tridium world, upgrade is a French word for you're ________ed.
    Been there, done that -- even with a new license and had problems. Stay with the version that you started the job with.
    NW Ohio
    Quote Originally Posted by beenaxed View Post
    I'd say some more training would handle your issues.
    I've had ZERO problems upgrading with the new license.
    Mount Airy, MD
    I'll second the zero issues, but I have heard of some having some. It seems it always has something to do with NOT following the instructions
    Ohio
    Did you try connecting to the Platform with 3.1? May be worth a try? At least the License version will match.
    I Keep AX 3.0.99, 3.1.29, 3.1.30, and 3.3.22 running on my laptop for different jobs we've installed. I just run the platform daemon for whatever version I need to run before booting up that corresponding version.
    Jogas
    Four wheel therapy, my 1968 Camaro is gone and will be missed
