Results 1 to 13 of 23
Thread: surging
    Oct 2008
    uae
    surging
    what is mean by surging?Iwant an explenation about surging on water cooled centrifugal chiller.
    it means you posted a technical question in the wrong area of the forum
    try the commercial guys down the forum a lil ways
    http://www.youtube.com/watch?v=nFl0n...ture=endscreen
    ottawa canada
    Every centrifugal chiller has a design "lift" . Lift is the difference in operating pressure between the condenser and the evaporater . If you exceed the lift the chiller will surge . During a surge the impellor/s are unable to overcome the pressure difference and the refrigerant rushes backwards through the impellor and in some cases stalls the motor .
    Surge is usually caused by too high tower water temp or in low pressure chillers by air or non condensables in the refrigerant side of the chiller (because of leaks )causing high head pressure but you can also have a low end surge which is low load .
    Try typing surge into the keyword search and you probably find lots of threads to help you .
    Whooo Hooo spring at last , time to get the toys out ........vrrrroooooom !!!!
    ottawa canada
    Maybe " Lord Edward J " can come on again and give us his sound engineering principles and advice as to what surge is again ????????
    Oct 2008
    Central Oregon
    It's "surfing" with a typo.
    Centrifs are not positive displacement type compressors and have limited ability to overcome pressure after the wheel ( in the condenser). The compressor uses centrifugal force for compression of vapor. The vapor enters the eye of the wheel, and is thrown outward by the wheel toward the volute and directed into the condenser. There is only soo much of this centrifical force available for a given wheel(lift). When condenser pressure is too high, as in the high entering water temp example above, the discharge gas actually flows backwords on the wheel as a surge. The wheel simply cannot overcome condensing pressure. kinda simplistic reply, but paints a picture.
    Quote Originally Posted by jakson mathew View Post
    It usually means it's screaming & moaning like a raped elephant
    N.E. IA
    [QUOTE=graham;2019246] in some cases stalls the motor .
    "As in, the motor stops turning?????????
    "Wheel" mechanics work on "Wheel" chillers
    crossville
    [QUOTE=referteacher;2020288]
    Quote Originally Posted by graham View Post
    more it slows the motor speed down to the point the motor will trip overcurrent protectors then its a shutdown and wait to restart cycle
    If you cant cool it
    HEAT THE Hello out of it
    Jan 2005
    surging and amp draw
    As gas flows backwards over impeller, amps drop off. When the lift gets to where impeller can do it's work again, it grabs all the gas it can and amps go way up (may be higher than full load amps).
    Cedar Rapids, IA
    Quote Originally Posted by jsherhvac View Post
    Now that is the most technically accurate description I've heard!
    Needless to say surging is not good for multiple components in the machine like bearings for instance.
    How can I avoid surging ?
    If surging is basically; 'exceeding the compression ratio of the compressor' - how can it be avoided? Most especially under low load conditions?
    And doesn't part-load operation accent the issue? I'n no centrifugal guy but if the load is low, the unit is unloaded, and the impeller is hardly pumping anyway, it seems like the two curves of heat load and compressor unload pumping ability have to cross at some point.
    What is the way to mnimize the effect? False load the chilled water loop with boiler water? Lower head pressure to follow the chilled water load down?
    Why wouldn't the controls be set up to cycle the machine off before surging occurs?
    PHM
    May 2008
    Jax Fl.
    Many years ago, I took a new apprentice into a mechanical room where an old sidewinder was running and showed him the control panel that was tight against a wall. I then explained how these machine were know to make a loud noise and then explode like a 2000 pound bomb, while all the time turning the load limit percentage lower and lower.
    When it surged it scared him senseless.....That was as much fun as sending them into the air box and turning off the lights just as you started the huge fan which filled the room with belt squealing/rubber smoke...
