    new to commercial equipment
    i work maintenance in an old building so there is a lot of equipment not used much these days. i was wondering, we have a Governair for one of the newer parts of the building. are these very common? i can get information on it tommorow if that is too general. we seem to have a problem with losing compressors in it and its a pita to change them. they seem to liquid slug a lot. the more experienced guys i work with say the expansion valves on 2 of the compressors are not sized very good and they have a lot of junk in the coils from so many compressor burnouts and from valves breaking etc. is there a good place to get info on these? thanks
    never underestimate the power of the darkside.
    San Jose, CA
    Try Governairs website( http://www.governair.com/ )
    Yes these are common in commercial/industrial applications.
    Well made American units. Of course all HVAC equipment needs to be properly installed and maintained. I have worked on many Governair units and they all seem well put together. (accessable) service panels and typically well controlled. At least the ones I have seen.
    Chicago area
    If you are going through alot of compressors, two big things usually cause this. Crappy power supply (low voltage), and the other, poor replacement / system cleanup procedures.
    Los Angeles
    I've had six Governair units running for about 15 years and they have been reall workhorses. I've never had a compressor failure(knock on wood) but the factory auxiliary switches on the contactors are really prone to failure.
