    Apr 2008
    Upstate New York
    gas or electric WH ?
    Ok after reading about the tankless WH's i have a question, surprised huh
    I have an 80 gallon electric WH on a day night meter. I have elect range,dryer,central AC, and the WH . My bill when not using the AC too much runs about 75.00 to 80.00 per month. 2 people in the house.
    Now would I be further ahead getting a 40 gall and going back to a regular day meter ?
    Or putting a timer on my 80 gall and keeping the night meter but setting the timer so it comes on at 4am instead of 11pm ?
    I thought about a NG one but my neighbor has one and his bill runs more than mine with the same size and design house ...
    I also thought about a tankless but that doesn't sound like a good move right now. Someone here said a elect WH is 100% efficient which I guess it would be but I wonder if I am saving with the 80 gall on the day night.
    If I was to go to a 40 gallon the day night meter would have e run out of water some days so that option is out
    Apr 2008
    Upstate New York
    Oh also, IF we decided to go with a NG WH could we go to a power vent that uses PVC to vent thru sidewall ?? Do these use 2 pipes one for exhaust and one for combustion air ?
    Any problem using these in a basement that the furnace uses inside combustion air ??
    A powervented water heater uses 1 pipe.
    Your electric water heater has a recovery rate, of roughly 22 gallons an hour(depending how hot the stat is set).
    I would leave it as it is.
    A time clock won't save you enough to pay for itself for many years, if at all.
    Apr 2008
    Upstate New York
    Just so im clear, if thats possible. Which would you choose;
    1) 80 gall electric wh on day / night meter
    2) 40 gallon elect on regular day meter
    3) 40 gallon powervent NG wh
    Again I dont know why but my neighbor has same size house and everything only one person there and everything the same as me except she has a ng wh and her bill is abotu 10-15.00 more every month.
    I thought ng was alot cheape
    I'd stay with the 80 gallon with off peak timer like you have.
    NG water heaters have higher standby loss then electric water heaters.
    Apr 2008
    Upstate New York
    10-4, thanks
