    Air pipe beside the furnace
    Hello,
    I have an oil furnace. Beside my furnace is a 4 or 6 inch metal pipe that brings fresh iair straight into my furnace room. What is the purpose of this? Can it be blocked? It brings in air from our cold Canadian winters into my house. This must make heating my home more expensive and the electric water heater is 4 feet away. If it is a carbon monoxide problem, can I just get a detector so as not to have cold air coming into my house. And will putting an insulating blanket on my water heater make much of a difference in my water heating costs?
    Thanks,
    Francois
    Oct 2007
    Can u post a picture
    Jul 2001
    Your furnace and water heater are in a confined space and the pipe you describe brings in air for combustion. Do not block it. You can eliminate the pipe if you install high efficiency furnace and water heater and run direct vent PVC to them
    Jun 2007
    Round Rock
    It is called combustion air. Fire (your flames) need oxygen to burn and this brings it to the furnace so that it will light and not backdraft when you open the door to let oxygen in. Leave it as is or risk danger, it has nothing to do with carbon monoxide levels. I would suggest insulating the water heater and insulating the room as much as possible to keep the cold out of the living area.
    Jul 2005
    fhebert; if you install the pipe approx 1 to 2 inches above the floor level inside a pail or bucket it will only bring in enough air for combustion purposes whenever it is required.
    This is called the "anti-spill" method.
    Try it, it works, and sure cuts down the on the amount of incoming air when not required.
    Westlake, Ohio
    Quote Originally Posted by deejoe View Post
    Excellent deejoe!! Could add 2 - 90 degree elbows if you don't have a bucket. This is called a cold air trap. Also keeps warm air from sucking out.
    captain CO
